my 240's dyin..
drifter sx
Car: the usual
ok im in a serious situation. i have a blown head gasket, bad transmission, and no clutch left. plans are in motion to replace the transmission and clutch, but that damn head gasket is really expensive and will have to wait for a few more weeks. but [and i know im stupid for doing this] ive been driving the car everyday to and from work, and theres this ticking noise that seems to be getting louder and louder. well, about an hour ago, my car shut down as i came to a stop light, and it wouldnt start. it took a few minutes of struggling but it finally came back on, barely. just enough to get me home. can i save it or is it fried beyond repair??
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
YOU NEED TO SEE WHAT KIND OF INTERNAL DAMAGE HAS BEEN DONE. I CAN BET THAT SLAPPING A NEW HEAD GASKET IN THERE AT THIS POINT WILL NOT FIX IT. JUST TEAR IT DOWN AND REBUILD IT. IF NOT WHAT KIND OF 240 IS IT? IF ITS A 91+ HATCH I'LL BUY IT AS IS IF THERE IS A TITLE AND NO CHASSIS DAMAGE.
quiksilvia
Car: 95 s14 se
that caps thing is funny, but if i were u, id get a sr20
red240ne
Car: mmm...donuts
head gaskets are 20 bucks. it's an easy do-it-yourselfer.
wiwalsh
Car: school, and my 240!
as long as the only reason the head is leaking is a blown gasket, and not a warped head.... Have you checked your oil and coolant for unusual color??
Dattebayo
I think wiwalsh is trying to find out if it is an internal or external gasket leak. Internal leaks have all kind of problems like engine overheating, oil-smelling antifreeze, engine running like crap. External leak will not cause too much damage, just spreading oil all over the engine bay and losing compression. (there are lots more, but i dont wanna list em) That ticking could be anything though, and could be a sign that it might not be a head gasket. Just how do you know the head gasket is blown? Shop or personal experience?
240_Keyy
Car: '90 240 Fastback
John, did you ever do a compression test on that motor? Also, did you ever get that problem fixed with your radiator cap and what not?
Gimme a call or something, I am back from Austin now...
180sx
hmmm defenatly compression test how bad is head gasket did you like melt it does it burns ****loads of oil and antifreeze you need a new head i say you probably cracked it.defenatly do compression test good engine will give you 175psi per cylinder
