what he said.Hijacker wrote:CHeck the journal guides on that camshaft to make sure the cam was seated properly. That damage looks like the cam was angled improperly and the chain put tension on the end that snapped it.
time to get back into civicsBlack on Gold wrote:Your giving up after that?
Torsion breaks leave a spiral break on the cam. His cam doesn't show that. It's a clean snap.duffman1278 wrote:That is TORSION my friend! More than likely it was your chain that broke it based off the looks of that. The shaft was probably getting stuck somewhere and the torque from the chain, produced by the crank just wore it out and SNAP.
EDIT: Another possibility is overtorqued cam bolt
