rioredstang »
https://forums.nicoclub.com/rioredstang-u121266.html
Sun Nov 21, 2010 5:57 pm
Well you have to weigh the options here. If you buy another used engine you don't the condition of it. You could be buying one with problems. Install it and 2k or 3k miles and bang. Head gasket, spun rod bearing, or something else. You just don't know.
Now if you rebuild the engine you know what's been done. You may have to spend twice as much money to rebuild, but you can build to your specs. New bearings, pistons & rings, line bore block, valve job, check crank, now you have a new motor that you can run and not be scared its going to blow.
