My 2009 FX50s doesn't have bluetooth. Whats the best way to get it ?
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
BobbyGerm
Car: 2009 Infiniti FX50 S
Can I purchase a used 2010-2014 radio with bluetooth and will it be a plug n play ? Do I only purchase the radio or also the screen too ? Or is there an alternative solution ?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
From what I can see, the base sound systems in the FX all used a "telephone adapter unit" right through '14. So you'd have to upgrade to a navi to get bluetooth self-contained, and frankly that's impractical. You'd be into changing both the Main and Body Harnesses or doing a ridiculous amount of rewiring and new wiring. You'll be much better served to go aftermarket.
OWC
Car: 2006 Infiniti G35 Coupe
2008 Infiniti EX35
If you wanted to upgrade to a 2010-2017 Nav system with bluetooth and everything you could do that. You'd however need to adapt wiring (pinout, cut, splice, etc.) or purchase a harness adapter kit, such as this one: https://www.ebay.com/itm/334124253577
Once you have the wiring in order you could then drop the parts right in.
If your main goal is to get bluetooth, there are a few alternatives in addition to what's mentioned above.
Let us know if you have any other questions.
VStar650CL
Technical Expert
OWC wrote:
Tue Aug 24, 2021 3:34 pm
Had no idea anyone made those, good info!
imnprsd
Car: 2004 Infiniti FX45
With this bluetooth connection to my cell phone... and an FM connection to my radio... I now am able to quickly hear my cell phone calls (very clearly) over my Bose sound system. And I like that it measure my DC system voltage so I know if my alternator is putting out 14.0V.
https://www.amazon.com/dp/B08L3WX26S?ps ... ct_details
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
