kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Fri Dec 19, 2008 9:26 am
Hmmm, I don't fully understand, why would you want to use the park brake while moving to bring you to a stop, rather than just pushing on the brake peddle? If you do this, I don't think the ABS would work properly or at all. Also, I wouldn't recommend throwing your vehicle into park when moving, under any circumstances. If you hit a dry patch that could be ugly, and you don't want to take a chance with the transmission, very expensive to replace. I think you're over thinking things, the idea behind ABS and traction/stability control is that the computer takes control of these things, but if you start doing unexpected things like setting the park brake or putting it into park while moving, I think you'd be asking for problems. An expert would be able to give a better technical description for sure, but I think the message would be the same - don't do this!
