ok sorry for not posting any updates in a while. i was getting kinda overwhelmed with the build and thought i wasnt going to finish in time. I have about 6 days before the car will be unveiled and so i might or might not post the finish product cause i might be 2 tight for time. But anyway here is what I've been up 2.
those whelen lens are finally polished.
the beginning of the box
side note- i have tail light covers that i never replaced cause the only thing that it needed was new paint. here is the before on the right and the after on the left.
rear panel of box
getting some ruff cuts done
so i got the metal roof rack, those yellow oxygen tanks, and the whelen 9000 frame back from powder coating and holy cow it looked so sick i had to do a quick mock up of what ever i had. i was excited !
even just having one of the spot lights mounted for a quick second and i knew this was a great freaking idea.
back to the build.
all primed and caulked
i had to back track since i forgot about this piece and then it showed up in the mail. just setting up the mounting points
modern fan box complete
solar panels mounted
so ive been making some changes with the design of the rack, but not going over board to where it doesnt make sense. i wanted to add something to the walls that are visible on the outside. so i got the idea from the milk crate i sit on while building lol. i took the pattern off that, got in drawn up and made into a decal.
before
after. i am really pleased the way it came out.
heat sink painted and installed
mounting points for the box to attach to the frame
so thats where I'm at fellas. also in this photo you can see that i got the metal box powder coated a gun metal grey.
oh one more thing, on the real ectombile it had a large Whip Antenna mounted to the side of the car. I wanted to get one but i didnt want to drill into the body of my car. so i poked around until i came across a antenna mount for my rear brush guard. I went with a firestik cause i felt it went with the style of the build.
i hope you like my work so far and let me know what you think!
