Amen!mrclean2 wrote:The look of the car is beautiful The features are excellent The ride is incredible...
but the oil change is hell18 screws to remove the cover to get to the oil plug and filter. You've got to be kidding me!
I've been on my back for longer periods for things more enjoyable than this.What a beat down!
Can I get an Amen!
Nope! My BMW 540i had this flap. Run it up on the ramp. Drop the flap, drain, change and you're done! The M45 has the one big cover that takes me 15 min to remove.szhosain wrote:
Amen!
But, you can make life easier for yourself ... there is a little flap on my 2003 M45 that only has two screws. This flap is designed for access to the oil filter and drain plug. Do you not have this flap on your car too?
Z
I'm sure, because the manual says to and I stayed on my back for 10min just to make sure because I still couldn't believe all that had to come off for a 10min oil change.sr79labrat wrote:Thats gotta suck! Are you sure....dont see why ours would have one and yours wouldnt?!?!
That is a pain!KTW
I can see the logic in that, but how can you get the drain pan under it enough to where you dont spill or get any on the cover? My past cars have all had the flap to get to the plug without so much effort. I must say that BMW has made it much easier, but that's a small price to pay for the joy I get behind the wheel.jankenpo30 wrote:The 06' does have a flap as well. If you took all 18 off, you wasted your time. The four screws located closes to the rear is all you need to remove, bend the flap back and use something to hold it in that position. I used a short piece of 2x4 I have. Change filter & oil. I'm in, draining oil within 5 mins, done within 15 mins.
Of all the cars I've own, this perhaps is the most convenient oil change I have to do. The filter & drain plug are right next to each other.
Which model year are we talking about here? The new gen M's are a *****. Yes, you can bend the cover back... but they should have put an easy access flap there. Then, you have to contort your hand to access the filter, which is tucked behind some bars & brackets...Double E wrote: this is probably the easiest car I've worked with to change oil.
