SOCAL91Q45a wrote:Hey guys ... I got a flat tire!!!
"use about 1/2 the can of cleaner, on the MAF, and surrounding intake hose. Use the whole can of FI cleaner on the throttle body, and butterfly valve. Change out the battery."
Jeff Williams
Jeff luv ya brother - but like every post recently seems like the ultimate solution is to CLEAN the MAF - LOL .... Just a funny observation - laffing "w/ you" bro - not AT you. Dont take it the wrong way .. Im in a goofy mood.
I'm cool. Goofy moods run rampant, in my house. Actually, the last flat tire I had, I used a can of brake cleaner on the MAF, and the car ran much better, except it was a little lopsided.
I guess the reason I mention this process so much, is because I clean mine, once a month (product of dusty jobsites, and my K&N POP charger), and the car runs like is brand new, afterwards - everytime. You can't even fell the idle at stop lights.
I paid $65 to find this out out the first time - the dealership cleaned it for me.
I figure I have saved $2,500 in dealership visits, just by advice like this, on this site, and just want to pass it on.
Robert, The MAF is the sensor just downstream (towards the intake) of your air filter. It takes about 30 minutes to disassemble the box, and hoses. Then another 30 minutes to clean everything. Let it dry out for an hour, then re-assemble. If you clean the butterfly and throttlebody, it may be hard to start. If it dosen't start like usually, just floor it, and keep turning over the engine, it will fire. (This is the way to start a flooded Q45).
This is just a little harder than changing the airfilter, or oil.
