szh »
https://forums.nicoclub.com/szh-u149.html
Fri Feb 02, 2007 9:47 am
If you plan to keep the car for a long time, then a simple, cheap rebuild will not be the right way to go. And, I would not trust AAmco either!
The right solution, albeit a bit more costly, is to get an Infiniti refurbished one. Costs about $1850 (with core return of the old one) from Joe Tsensky at ww.everythinginfiniti.com for example.
Then, the labor costs to get it done vary a bit depending on where you are located. I had an Infiniti dealer do it for about $800. They gave me a 1 year, 12k miles warranty.
To keep your replacement transmission going well, use a good synthetic ATF (like Mobil 1) and do regular full flushes (not just a simple replacement) every 25k miles. A flush costs about $139 to $199 - depending on the dealer with the right equipment - and well worth it in the long run!
Z
