gitcash2009 wrote:I noticed a blue flash of light coming from the passenger wheel well up under the hood near the starter realy and a ground wire going to a dc power unit near the abs and starter relay everytime you try to sart the car.
It sounds like you have a wire arcing in that area. All of the wiring in this area needs to be inspected. It sounds like the stress of the electrical problmem has drained your battery (the click click click that you heard trying to start later).
Check your battery voltage at rest (should be about 12V), during starting (a little below 12V, but not much.. maybe 11 or higher), and during idle (about 14V). This isn't a substitute for a good load test, but it'll usually tell you if your alternator and battery are OK.
Heath
