kfirestone »
https://forums.nicoclub.com/kfirestone-u72298.html
Mon Jul 30, 2007 12:35 pm
Ok, here's the scenario. The electronic radiator fan stopped working, so I got out the volt meter to see if power was coming into the fan. No power to the fan, so I checked for bad fuses - fuses ok, but no power coming into the fuse terminals, so I got the bright idea of doing a bypass directly from the fan to a fuse source (the fan works with direst power). This is where the problem started. Like a dumb sh-- I connected one direct fan bypass wire to the battery and touched the other wire to the ASCD Hold terminal and the car sputtered, stopped and she won't start now. I dont hear the fuel pump come on and I checked the fuse in the fuse box and it's ok. Any ideas guy's (and gal's). Thanks, Ken
