maxnix wrote:1.) Fuel pump and O ring from Joe is ~$270. When FPCU blows (performance is noteceably decreased) it is $700 from teh dealer. Less if you can find one used. Why risk it?
The bottom line for me in this discussion, is the fact that I've been assured that there's no problem or sign of one now, in regards to the fuel pump. If it dies, it dies. If it takes the FPCPU with it, it dies and costs me more money - but in the meantime, I'll be able to spend that $270 on fixing up my Wrangler. The Jeep's prior owner wasn't even remotely as good with his maintenance as my folks have been, so there's a lot more "remedial" work to be done there. Tires that are 4-5 years old, for example. Fluids that may not have been changed... well, ever. And this is a '95.
In regards to the Infiniti, I'm far more likely to be inclined to spend a bunch of money on it in order to deal with the wheel-rubbing issue that I've mentioned. That's at least a known, physical problem, that might take the car off the road by being a safety hazard. Once I get that looked at, and once I get the Wrangler fixed up to be my daily driver, then I'll start looking ahead more long-term with the Q.
I can recover from an FPCPU death, especially considering the sentimental value this car holds for me. If that worst-case scenario hits, it'll be off the road for a month or so, but it'll recover. I might not be so lucky if a wheel falls off at 70.
