infinitiboyj30 wrote:My j30 idles to 1,000rpm when its warmed up and I go for a full stop and my heat is on but when I turn my heat off it drops 2 sticks under 1,000 why is that? It idles normally when I turn the heat on...Also it stays below 1,000rpm when I go for a full stop but when its in park it goes up to about 1,000? I changed my spark plugs to oem ngk laser platinum,pcvs,fuel filter and still no help with the idle issues....and my old plugs were still good and the same oem ngk laser platinum is what the mechanic told me so I'm waisting my money here trying to fix this issue so I dunno what more to do
i know my car idles almost the opposite...when i turn the heat on my rpms go up...lol..w/o the heat on i idle at around 600-8-- rpms....w/the theat on im at around 900-1000....u might try cleaning the EGR tubes,MAF,and replacing the air filter...might not fix ur problem but it helps eliminates the possibilities...good luck...also check ur ECU...maybe an old stored code or something...
