my 1992 240sx stalls .......
tony/ka24de
my 1992 240sx stalls when the car is hot. Cold starts are fine. But after driving it and turn it off for 10 min, I have trouble starting it and when it starts it bogs for a bit. Does anyone know what this might be.
ziggy682
Car: 1991 240SX Turbo
Leaky injector?
tony/ka24de
only when the car is hot, can't be
ziggy682
tony/ka24de wrote:only when the car is hot, can't be
Actually 2nd generation RX-7's are notorious for exactly this problem. Cold starts are just fine, but there is a problem with the ECU that leaves an injector open occasionally when you kill the car. All the pressure in the fuel rail leaks out through the open injector, filling the combustion chamber with gas. If you try to start the car, it won't start because it's flooded, and rotaries don't like to unflood themselves. Once the car has sat for several hours, the gas will evaporate, and the car will start like nothing's wrong.
So, if you have a leaking injector or o-ring, when you kill the car, it will flood it as it releases pressure from the fuel rail. This could be your problem, or it could be a hundred other things. I was just throwing an idea out there.
ricebike
2002 Quest
2005 Altima
yes, one of many that can go wrong w/ this condition...too many to list soo:
just d/l the FSM that's floating around this site & start reading the diagnostic process...
tony/ka24de
thanks guys
SunshineAcid
Car: 89 240sx Ka24de swap
sometimes the RX& problem is grounding (i know, i have one)make sure your ecu is grounded properly
