nomoactivesuspension »
https://forums.nicoclub.com/nomoactivesuspension-u26677.html
Tue May 08, 2007 12:16 pm
My problem first started when my Q would stall and a message on the display would say low battery charge and when i tried to restart it would take 20-50 seconds of starter cranking before it would turnover. While the engine was running a check engine light would stay on then go off. I had the interstate workaholic battery load tested and to be on the safeside i put a remanned alternator in to it. I took it to a shop(independent) but they said they could not retrieve the code from the ECU so i got one from POP POP and car will not start. When i attempted to start car after 230 seconds of cranking i smelled a little gas. So its getting fuel. This Q has 203k and has been through the usual stuff: chain guides(2000)crank angle sensor(2003) new fuel injectors, plenum-water,gas and vaccum hoses(2004) fuel pressure checked,new fuel pump,gas tank and sending unit.
