jjbuzzman wrote:My two 1990 Q45's have, IMO, the perfect steering "feel." It's a delicate balance of road feel, responsiveness, and sense of handling. My '91's steering requires more pressure, has less road feel, and is much duller. These 90's and 91 are stock with Tokico's and 15 inch tires. My '93 has Q45a rear sway, Tokico's, polyurethane bushings, 245/45/18 tires, etc. so the overall "handling" is very good, but the "steering feel" is not as good as my 1990's - the '93 has lots of road feel, but the steering is too "light' - as if it has too much power assist.
Given these cars use a lot of interchangeable parts, this difference does not make sense. Is this situation just a peculiar artifact of my particular cars, or do others also notice some difference in the steering with the 1990's as compared to later years?
I've never driven another Q to compare with mine. The 90-93 models had a 15.1:1 ratio for steering. I know in 94 they changed it to 17:1. The slower ratio was to make it feel more luxurious I guess and justify the price tag.
I thought 90-93 were the same. Do you have HICAS? I hear it makes the steering feel loose. How about your steering link bushing. I think mine is worn. Sometimes my steering wheel looks like I'm turning slightly (like a lane change) but the wheels are aligned. I've let go of the wheel to check my alignment, and I can't see any sort of pull or drift. I'm guessing it's the rubber bushing.
I wonder how my 90's steering would compare to the 94-96 series?
And that will get us what?Q45tech wrote:Count the number of full and partial turns of steering wheel. 1.25 + 1.25
Uh, you posted a cryptic answer to a question no one asked. No one asked you to get the spoon out.Q45tech wrote:It will tell you the steering ratio since the max tire angle is in FSM.A turn is 360 degrees. 1.25 =450/ 30 [tire angle]= ~15:11.5 turns x 2 [3 total]= ~ 18:1
The FSM has a range of possible tire movement so you will have to measure that to get EXACT steering ratio. The toe will change ratios
Spoon feeding high school trig again.
<------Q45tech wrote:Count the number of full and partial turns of steering wheel. 1.25 + 1.25
Not after 1994. When one calls Joe for a new Infiniti rack (~$1,100), there is only one part number for any G50 model year.Haitian_King wrote:(Except for the Q45t version which retained the original 15:1:1)
The original poster would have to have teh same tires with the same wear at the same pressure with the same wheels and shock wear to truly compare just the sterring ratio and preload.Q45tech wrote:So individuals will need to reset things to match tires they are currently using.
