homeslicej2 wrote:Wow RB25DET, that's sweet. I forgot to mention earlier, but if you haven't already, you should take out the dash support crossbar, get all the rust off, treat it with rust killer, and paint it too. Since you have the dash out it would be a good idea, not to mention easier to do. You have plans to race the car any? just wondering because the stock KA24E weighs 493 w/transmission and the RB25 is around 735 and of course longer since it's a 6. It throws off the balance of the car a bit. definitely post some pics. I want to see the motor installed, and post any dyno numbers you get. If you dyno it that is.
Beat you to the painting of the support, it just takes a while to get pics on here. As for the weight issue, its not really even an issue. Yes the RB weighs more, but you need to understand that it is longer, i dont know your educational background, but its easily understood with a background in statics and dynamics. Also the additional weight is also in the transmission, the transmission is close to the center of the chassis which reduces its effect on handling since the additional weight is applied to all 4 spindles rather than the front 2. A complete KA24de weighs in at 540lbs on the scale, and the Rb25det weighs in at 720lbs. This is a 180lb difference. Yes, some of this 180lbs is putting more weight down on the front end, but like i said before its not like your putting 180lbs on the front bumper, the additional weight is spread from the radiator support back to past the shifter. It would take math and measuring to figure out exact numbers but it is obviously an insignificant number. Just think, gas weight an est 6lbs, with 15 gallons of gas in your tank, your adding 90lbs to the rear of the car then your on empty and taking 90lbs out of the rear of the car but the handling still is very close to that of the full tank of gas. Or how about when you ride with a passenger, the average male weighs somewhere in the are of 180-225lbs. Does your car handle awful when you have a passenger, no. Vehicles are designed to have verying weights in them, thats why they mark on you door sill the allowable changes in weight. Hey i dunno about you but id rather have the 300+ Hp with a resonable stock RB than the 130some of a reasonable stock KA. People can argue the handling issue all they want but it doesnt get them anywhere becuase the swap is still going to be done, and its still not going to make a noticeable effect in the handing aspect of the car. Even if it was a huge difference, suspension tuning would allow the weight to be compensated for. No built car has the same weight bias as a 100% OEM car, just due to the fact that people take off things to lighten it, change the tires and wheel setup, add turbos and other various items that all add and remove weight. This whole weight arguement has been done too many times, the biggest variable in handling with out question is SUSPENSION, you can ask any chassis builder and you will always get the same answer. Here is a set of shocks I have, axis racing, penske built, nothing will effect handling more than a set of good shocks like these but youll pay ($1500 for these 2 shocks pictured obviously they are not for a 240 but they are real racing shock absorbers, the most influential aspect of handling)
