Haven't updated this in FOREVER:
hellz yeah
First, some day shots of the car. Looks a lot different, huh?
Next I made some coolant pipes (i installed the IC piping to ensure clearance)
Shot of the intercooler and radiator installed (temporarily):
Then I started installing the window gaskets and some of the trim. The trim is actually blacked out with vinyl, which is a pretty popular way to do it. It looks really good:
Lastly, I made and installed some AN lines to be used with my PCV vacuum setup. That unaatached line will go to a catch can, then into the exhaust evacuator.
Got my coolant pipes coated in brushed aluminum PC and my bumper brackets in black.
I put a bead on the pipes with these vice grips I modified. Got the idea from Dan (JUICEDZ4)... In fact that's actually his pic... but mine are nearly identical.
Check out his AWESOME cavalier build here. I know it's a Cavalier, but check it out, it's unreal.
I bought some cheap summit racing window cranks and machined an adapter to run them on my gutter power window housings.
More shots of the outside. It's even more yellow than it appears in photos. Very odd color indeed. 4/6 windows are in. As is BLACKED OUT TRIM
PHAT AZZ... (the apron has some black on it at a weird angle so it looks crooked, but it all gets covered by the rear valence) Also got the trunk latch and tails installed. Looks like a fox notch hahah.
A shot of the CHROME BILLET WINDOW CRANK$$$ installed (23 bucks from summit)
And FINALLY got a set of these. SOOOO much better than a crescent wrench with electrical tape on it.
Also summit racing must hate that I keep adding s*** to this order over and over. Check out all those different ship dates, all on 11.95 handling.
Nah, they probably love me...
Look at all this other s*** I ordered.
Added a line clamp for the oil feed line and installed the EGT fitting into the manifold. The schedule 10 should be thick enough to not weld a bung on there, time will tell.
Powdercoated coolant pipes installed, you can also see where I am going to weld the BOV flange on.
Steph's baffled catch can installed. You can kinda see how the lines route now. One more line comes from the bottom of the catch can to the exhaust scavenger, which will be after the WG return and flex section.
A shot of the line feeding the catch can and also notice the brake booster check valve installed in-line. Again, trying to keep it ultra clean looking, this time line mounts to firewall.
Rear PACKAGE TRAY dyed black and installed. Instead of factory mounting I simply chose to use 2 stainless self-tapping screws in the front and clips in the back.
Lastly for tonight: Back Glass.
Just scooped up this, and the interface to communicate directly with AEM:
http://www.race-technology.com/dash2_2_31.html
And a fuel sender from summit. (Oh yeah and a 2.75 cent fitting that's backordered until october, LOL)
First thing I did was install the fuel tank level sending unit. Pretty straightforward.
Radiator fan installed:
Wideband bung welded on:
Spiffy downpipe bracing to motor:
Lastly, and most awesomely, I made this closeoff out of laser cut aluminum and pre-preg carbon fiber.
