flinterman2000 »
https://forums.nicoclub.com/flinterman2000-u133168.html
Wed Feb 17, 2010 5:05 am
Sorry for the late response, but my computer crashed. I used a high pressure pump from a fuel injected engine and a fuel pressure regulator from MSD which I sourced from a local parts store on my Mitsubishi Galant. The pump output was 45 PSI max and was regulated to 7 PSI at the manifold. Had problems at initial full throttle as boost spiked to 10 -12 PSI on first demand. As for the head bolts I can't say. When the engine was built the bolts were sourced by a friend who didn't say where it came from. It was a Z20 with 4 speed automatic, shift kit in the transmission and 32/36 webber. When I added the turbo I changed to a 34/34 ratchet webber.
Modified by flinterman2000 at 7:10 AM 2/17/2010
