my 1985 300zx
A home for 1983–1989 300ZX owners!
p03tic_mind
Car: 1985 nissan 300zx turbo
i am new to the world of the z and i have a lot of question for you more experienced folks so here is the first of many questions im sure can anyone tell me how much boost a stock 1985 300zx turbo has
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
az zbum would be the expert but I think the stock wastegate actuator is supose to open around 7psi
Perrenial Badass
Car: 1973 240Z, 1986 300ZX, 1987 300ZX, 1984 Corvette
http://www.az-zbum.com/index.shtmlhttp://redz31.net/
Do a bit of reading there. ZBum's site has the stock info, whereas redz31.net has the modifications info. Both are worth the time to read.
Oh, and redz31.net used to be redz31.com... the old domain name expired and Jason (site owner) wasn't able to renew it for whatever reason. So if any of the links don't work, just replace the ".com" with a ".net". You may or may not have to do this, I'm not sure how far he has gotten with changing these links. And I sure as hell aren't going to go through all the links to check for you.
But to find the answer to your question, go to ZBum's site and click on "Z31 Information". Look around for something about the turbos specifically... click "Basic Z31 Information" and look in there. Well, nothing on what boost levels there are, but there were apparently "three" different turbos on the car. Go back to the last page. There is a link called "Differences", so you click that since there were different turbos. Amazingly, the info you seek is in the first four lines of that page. Just find your year car (85) and look at the stock boost (6.7psi).http://www.az-zbum.com/informa...shtml
^That's pretty much how that site works though.
p03tic_mind
thanks guys for helpin out the newbe those are some great web sites and to tell you it is 6.7 psi
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
Perrenial Badass wrote:But to find the answer to your question, go to ZBum's site and click on "Z31 Information". Look around for something about the turbos specifically... click "Basic Z31 Information" and look in there. Well, nothing on what boost levels there are, but there were apparently "three" different turbos on the car.
Yes it does. In the first section...
Engine:bore = 87mm; stroke = 83mm; 6 cylinder, "V" configuration84-87 Z31 NA: VG30E, CR 9.0:1, 160hp @ 5200, 173ft-lbs @ 430088-89 Z31 NA: VG30E, CR 9.0:1, 165hp @ 5200, 173ft-lbs @ 430084-87 Z31 Turbo: VG30ET, CR 7.8:1, T3, 6.7psi, 200hp @ 5200, 227ft-lbs @ 360088-89 Z31 Turbo: VG30ET, CR 8.3:1, T25, 4.5psi, 205hp @ 5200, 227ft-lbs @ 3600
Perrenial Badass
Wow, I'm smart.
Return to “300ZX (Z31) Forum”
