My 1981 720 King Cab
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
DylanM
Car: Datsun 720 king cab 2wd
So I have added a new vehicle to my list, this here is a 1981 Datsun 720 King Cab 2wd. It has a 5sp, a/c, and some weight reduction (lil' midwest rust). Found out it has a lsd, was on a hill with gravel and it started chirping went back around and was delighted to see 2 marks. It is a fun little truck, I say it is a truck fit only for a king. :D Anyways this thread would be useless without pics so here is my new truck. The 720 King cab
It has a z22 4 cylinder, 2.2L, 2 plugs per cylinder, carbureted, 87mm bore x 92mm stroke and an 8:5 CR (sure you guys know already)
This is my first love my 1985 toyota supra, 5sp, lsd, IRS, inline 6 twin cam, ect.
PEZi
good stuff man! welcome to NICO
i wouldn't be too sure it has an LSD though... my truck (as seen in this pic) leaves marks from both tires when it gets sideways as well... but i promise in a straight line you'll only light up one of them... it has an open diff
84Nissan720
Car: 84' Nissan 720 2wd Standard
Nice truck and welcome.
PEZi720 wrote:good stuff man! welcome to NICO
PEZ that's an awesome looking picture
Roby
DylanM
So my truck runs fine at cruising speeds (0-35), but when you go up to say 45-55 it will do fine. Then out of nowhere it will stutter and stop holding speed. The tach goes down and if you try to give it gas it will do nothing, basically i have to pull over and try at it again. its usually in 4th gear and sometimes even 3rd. it is very annoying and I want to fix it so i can drive it at those speeds worry free. Any input is appreciated.....
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Does it stall completely? If not then you got a fuel restriction some where. What kind of carb are you running. Check the filter, then the check valve in the carb. Hey Piez, it could have an lsd. They're rare but they're out there.
Return to “Datsun 720”
