http://www.youtube.com/watch?v...edded
[infomercial voice]Do you want to avoid possible RROD occurances?
Embarrassed by that ugly Xbox 360 sitting in your entertainment center?
Do you just have TOO damn much space in your entertainment center?
Do you find your Xbox 360's factory fans intolerably quiet. Do you wish they would make their presence known not only more prominently while using the console, but after you've turned it off as well?
Fret no more, because the HumongoWhattheHellisThatThing from NyKatz is here!
The HumongoWhattheHellisThatThing (HWHTT, pronounced like you're hocking phlegm) increases the exterior dimensions of your Xbox 360 console by nearly 50 percent! Additionally, it adds two new noisy fans facing a completely unventilated side of the case, ensuring they will provide absolutely zero useful airflow to the system while adding ambient noise to your gaming experience.And as an extra bonus, the HWHTT provides the only TRUE solution to the Red Rings of Death problem. In the event that the HWHTT's poorly located fans fail to compensate for the increased heat soak of leaving your console inside the sleek, shiny, sexy enclosure, the HWHTT's faceplate obscures those ugly red lights and presents you instead with a lovely and futuristically sleek blue ring. Now you don't have to worry about those red ring disasters ever again!
Lines are only open for the next 12 minutes. Order yours TODAY![/infomercial voice]
