mustang rims?
fresno240sx
i was thinking of these wheels on my convertible..i just did my s13 silvia front conversion, will be putting on silvia sideskirts and rear lip...car drop on 2 inch springs...will this fit?
http://www.cruizinconceptswhol...CKAGE
s13beast
Car: 94 5spd silvert S14 SR
91 hatchback dd
Yes. As long as you have 5-lug swapped.
fresno240sx
oh yeah, sorry about that, my 240 has 5 speed and 5 lug swap..Will I need any kind of spacer and is it gona rub ? not too sure on the wheel offset thing...and also do any one knows if these will clear the 26mm 300zx caliper ?
Modified by fresno240sx at 12:38 AM 12/3/2009
onosqv
Car: '92 240sx Vert
offset has very little to do w/ clearing z calipers, it's about the center hub distance from the inside of the spokes. From the looks of the picture, it probably won't clear your brakes w/o a spacer.
If you are lowered on springs, then there will likely be no rubbing. If you are on coilovers, you will probably need at least a 5mm spacer (depends on exact coilover setup & wheel/tire combo).
