Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Sat Oct 25, 2003 11:37 am
the stiffness(bound and rebound) of the damper should match the spring rate somewhat...
a lighter spring(stock to say 3kg/mm) will work fine with a slightly stiffer than stock damper(KYB GR-2, tokiko blue, etc)
a heavier spring rate(3kg/mm up) should be paired with something a bit beefier in the damper range, such as an AGX, BIlstein HD, Koni sport yellow, etc...
this is to cope tih the radical stresses put on the damper by the higher spring rate...avoiding blowing the damper out.-chet
