91nissantwo40sx wrote:ok so for 12psi is a walbro 255LPH fuel pumpgreddy spec m intercoolerfull exhaust
good for 12 psi?
what about 14psi?
also how much Horsepower at 12psi and 14psi?
my plan is to reach 300hp and thats good enough for me
All you really need is good gas.
I have run 14psi daily on that itty bitty t25 for a long time with no problems with the motor or turbo (considering that you got a good engine and turbo to begin with).
And you will start to run out of ceiling anyway because you should be about the 250'ish whp range and the maf is maxed out.
I also agree that you wont be happy with that for very long at all.. i went from T25 to S14 T28 to a PE1420 @ 20psi on my first SR S13.. and trust me unless you start to scare yourself you are not going to be satisfied. To go past the S14 T28 you are going to need a maf and bigger injectors.
So when people are on stock head, block and turbo and say man its so fast i usually endup laughing out loud and ask if they are really serious.
