Thank you all for your responses
I’m getting a basic turbo kit already assembled, so I don’t need any parts, but thanks for the links.
C-Kwik wrote:Forget all the engine work. It's not necessary. If your goal is 230 HP though, the engine work is complete overkill.
For $5000, you should be able to boost about 15 psi and have over 300 HP. Possibly up to 350 or so.
The over kill is “insurance”, so if one day I’ll be stupid enough to put a 75 shot.I want to spend less then 5k and I don’t need 300hp.
C-Kwik wrote:May I ask why you need response so much? It's always been my stance that I'd rather make more power and sacrifice response a bit. Lag is actually a lot of fun when you know there is a whole lot more coming. Total Anticipation.
It is a very unpleasant drive, when the car is so lagy, I know because I have a turbo Audi and it is very lagy (on streets) on the freeway it pulls on mustangs GT’s, but I do mostly city driving and I want the fun of having a responsive car, because if my car lags I’m just going to hate it.
Titan wrote:I think one of the major things you want to consider for responsiveness is short intercooler piping.
In other words, no FMIC for you. I believe I read somewhere that each 90-degree elbow of piping is equivalent to approximately 1 foot of straight piping in terms of flow efficiency. Don't quote me on this, but either way, more piping = more lag.
I was afraid some one will come up with that, and you are right, more piping = more lag, but there is no other place to mount it, I especially don’t want any hood scoops.
Red Lightning wrote:Well, if you really want response, and only 230whp, how about getting a straight T3
hmm a T3/T3 that might just work, I will look in to that.
klattr1 wrote: Jim Wolf cams actually made my car more responsive, but after 3000 rpm. If I'm racing someone on the street and I'm at 3500 rpm and I nail it, I pull alot sooner than I did with stock cams. But from a stop, you will lose some low end torque with Jim Wolf cams. I have the cams combined with a t3/t04e now. WOW!
JWT cams, I’ll give them a call and see what can they do for my turbo setup, but are you sure the car is more responsive rather then just faster because of the added hp from the cams?
klattr1 wrote:From a roll, the car is amazing. From a stop, without dumping the clutch, it seems like it takes forever to build up.It depends if you are looking for drag racing from a stop responsiveness or street racing from a roll responsiveness.What is the intent of your project?
It’s main purpose is a daily driver, so no drag racing for me, maybe the occasional race from a roll of from freeway speeds.
aleph1 wrote:you want response? Search for a Garrett VNT turbo, dunno if they make em anymore, but never the less, they will be super expensive =)
I did a search from the things I found, it just a fuel saving turbo, mostly designed for diesels or small engines, as we all know the KA is nothing close to small.
WDRacing wrote:If your keeping the stock CR then you won't lose any throttle response, and if you use a boost retard based timing setup, like MSD 6BTM then you won't lose your NA timing curve unless your already on boost. So Just get any of the readily available turbo kits with a T3/T4 with a .48 to .63 AR section. They will spool plenty quick and you'll be well over 230 with the money you have to spend.
WD
Thank you will keep those in mind.
