TDot »
https://forums.nicoclub.com/tdot-u191641.html
Tue Nov 18, 2014 1:10 pm
I don't understand exactly what the problem is the way you explained it. Is your issue that you have two albums with the same name, whereas you wanted both albums to be merged under one album? If that is the case, why would you think that would happen? Every single published album in the world has a unique identifying code. Nothing would recognize two different published albums and merge them as one just because names are similar(not that music box specifically works on that principle). It's not outdated, that's how it should work to prevent inconsistencies and errors. If your issue is simply both albums have the exact same names, you should be able to rename the albums; I haven't used the music box in forever, but I think I recall seeing that option.
If that is not to your liking, the other option would be to buy a compact flash disk if your car is equipped with that, and save your files as mp3 on that archived the way you want.
