Larz »
https://forums.nicoclub.com/larz-u216291.html
Wed Nov 21, 2018 11:02 pm
I've never used the HD in my 09 M35. I use the flash drive as it's much more convenient, operates with lightning speed and each flash card holds hundreds of tracks. I load the tracks onto my flash card (using a card reader and my comp) in such a way that the main file is letters from A-Z and under each letter are separate folders with the bands / artists that correspond to that letter in the alphabet. That way I go to my screen, scroll down to the letter U, and bammm .... U2 comes up, then UB40, Usher, etc. I pick the artist and those tracks begin immediately. I can also navigate up or down the tracks or folders using the steering wheel. The tracks play brilliantly and even use the surround / sound stage effects if they contain that info. Cymbals might come from the upper speaker on my door, while bass comes from all over, and the voice sounds center stage.
The HD doesn't allow you to organize tracks in a customized way. It just chucks them into a list willy nilly and organizes them using the CD info or embedded track info.
Of course, in true Infiniti fashion, the flash drive feature was dropped and is no longer available on any models.
