Bunshaw »
https://forums.nicoclub.com/bunshaw-u100210.html
Mon Jan 19, 2009 8:39 pm
That might be an issue for a warranty claim. I personally don't use the Musicbox feature other than ripping 2 of my CD's to try it out but I certainly wouldn't expect songs to disappear...ever. Any amount of unexpected deletion/removal is unacceptable. Since the unit uses a hard drive it makes me wonder what type of error message would be displayed if the disk started to have trouble. Hopefully it wouldn't consider all bad sectors a lost cause and drop the offending sectors and their associated files from the index. Data loss almost certainly has to be attributed to a failing hard drive of some sort since the design is a closed system.
laurin1, since you have an LE with the iPod connector and assuming you have an iPod, have you tried using the iPod or the CF slot as a workaround since you also mentioned that you already have your music in digital format? That seems not only faster, but easier to update than the Musicbox in your situation.
Workarounds aside, it still makes sense to have a Nissan dealer check into it. The Musicbox issue could have just been a weird bug but if its the disk it could get worse. IIRC, the navigation system is also on disk so I'm not sure how that could potentially become affected by a failing disk.
