boznuttz wrote:The first three cylinders were Bosch Platinum +2 colder gapped plugs, and the forth was stock.
This comment makes no sense; gap is the distance between the center electrode and ground electrode(s), heat range is how fast the plug conducts heat away from the center to the cylinder head. The gap is a function of the power of the coil and ignition system (the more energy the bigger the gap can be), while the heat range is a mechanical property of the spark plug.
As others said, this really isn't worth the time to type. Put a matched set of the right plugs in and then work from there. All that money Nissan invested in the ignition becomes reality at the spark plug. If you have junk wires or plugs nothing happens. It's even worse in a boosted application since you have additional cylinder pressure the spark has to jump across the gap in.
