murder/suicide for fuel rail nut!
Slipstream
Car: '94 Sonoma, '90 300zx n/a
How do you remove the nut attached to the fuel rail? It is the closest to the firewall slightly under the fpr flange? I've tried every tool I have and can't even reach it. It is on the bottom side of the rail connecting a flange that is attached to the rail(the top side has the zip-tie that holds the wire loom on.
Slipstream
This might help, 1995 ka24de.
j-z
Car: 95 240sx
ive never had a problem with that nut. youre talking about the one that also holds the intake mani to the head right? try some wobble extensions and/or a u-joint. mines real easy to get to.
Slipstream
I believe that's the one, the other 2 were on the intake manifold. I couldn't even get a finger on it. Did you remove any thing else to reach it?
navysnail
you said its under the FPR flange? you may have to pull some more stuff off to get to it.
Slipstream
I think so too. I was planning on doing the head gasket anyway, so I might as well do it all now. I have an extra set of injectors from a sr20de that I was gonna send to Deatschwerks as a trade to get these reworked. Should be a fun next couple of days. The problem is I think one of them is staying opened and it slowly floods if you don't start it at least every 2 days.
