Murano will not shift into Reverse or Park
Forum for the unique Murano, and official home of Nissan Murano Club!
kolkata
My 2004 Murano with less than 40k miles on it has a unique problem - as I see so far. Sometimes when driving and I am at a light I will put it on Neutral such that I don't have to keep the brakes pressed. Other day I came home and discovered the car cannot be put into Reverse or Park. I can only put it on Neutral and Drive. Took my car to the dealer and there it worked fine! Today unfortunately it is again acting up. Any suggestions? All required services - upto date.
shaqatk
Car: Crimson Black 2012 Nissan Maxima SV.
may b ur button that u gotta press to shift is acting up?
BBISHOPPCM
Car: '06 Nissan Murano S AWD w/ Convenience Pkg
I believe the problem is either a faulty brake pedal switch (do your brake lights kick on when the brake pedal is pressed?) or a faulty shift lever release solenoid.
Return to “Murano Forum”
