This can be done but the problem with this approach is that the lockout prevention mechanism will prevent using any power locks or intelligent key request switches to lock the door as it thinks the driver has forgotten to remove their key. It would be necessary to manually lock the door when leaving and if anyone broke in they could still start the MO and drive off since the intellikey is somewhere in the vehicle.martinrrrr wrote:Surely you're using the second key that came with the Mo. I'd use that while I kept keep looking.
Ah, I understand the full conundrum now. Get a strong telescoping magnetic pick up tool like that used by mechanics and search under and between seats and see if it picks up anything.Bunshaw wrote:
Luckily once locked, the intelligent key request switches won't respond to an unlock command from outside the vehicle unless an intellikey is also present outside which I think is the point you were trying to make.
Thank you evbdy for ur concern. I have found it finally.I had to remove the seat and look under the carpet. I think it is this pocket u were talking about!!brainguyus wrote:I have an '09 Murano so I'm not sure this applies to the '06.Check under the carpet where the seat frame bolts to the floor. There is a pocket under the carpet flap that loves to eat small items. It took me a month to find my thumb drive.
This may be a difference between the previous and 2nd gen MO. The vehicle would NOT allow you to manually lock or use the 2nd key because the 1st key was still in the vehicle? I'm a bit shocked at this behavior, it's almost the exact opposite on the 2nd gen MO's.alain_serhan wrote:
Martinrrrr, i couldn't use my 2nd key, i also couldnt close the door manually, it automatically opens because they key is inside.I did not take the key from the valet, i was drunk! dont drink if u have this car thanks evbdy
