Everyone standards are different as is their sensitivity to PERFECTION.Very few owners bother to remove shocks and use a shock dyno to test to see if they meet oem orginal published design stiffness.
http://www.shockdyno.com/http://www.cir ... ow....html
"Even shocks that are only half as good as new can significantly impact stopping distances. The Cologne Institute for Traffic Safety tested a vehicle with partially worn shocks and then tested the same vehicle with new ones. The used shocks increased the vehicle stopping distance by 21 feet, a 23% increase! (See chart.) Twenty one feet is about 1 1/2 car lengths – more than enough distance to prevent serious injury and property damage.
The same rules apply to cornering. In an emergency situation you need as much contact between the tire and road as possible. Without maximum contact the vehicle might not be able to perform the emergency maneuver necessary to prevent injury and property damage.
The average age of vehicles on the road today is 8 1/2 years and is continuing to increase. Thus, an increasing number of vehicles are going to need shock service.
Unfortunately, customers do not often identify the need for shock replacement because the change has been so gradual that they have accustomed themselves to the degraded ride.
