Murano High Pressure PS line replacement question.
Forum for the unique Murano, and official home of Nissan Murano Club!
nitrod86gt
So my 2003 Murano 2wd SL is dumping fluid out of the High Pressure line for the power steering system. Looking at it, it's tight but definitly doable. My only question is how the hell do you get to the top bracket under the intake?? From the looks of it you maybe remove the plastic intake snorkel after the mass air meter and snake your hand behind there? I'm hoping I don't have to drop a mount somewhere to make it more accessible. Anyone that's done it feel free to chime in.
mfifield
Did you have any luck with this? I just ordered the hose and need to replace it soon.
bigkevin5150
I just replaced my hp ps hose. I have a 07 awd. Nissan wanted 270 for it. I had the hose rebuilt for 45 dollars..witch at that point I'm thinking cool this is gonna be easy..lol..so come to find out there is a bracket behinde the air intake.10mm bolt..how did I get to it??? I use a small mirror and jamed my hand in throw the left side. There is just enough room right on top of the intake to get the tips of your fingers in there..use a box wrench..same to put it back on..kind of put the bolt in a socket with some tape stuck to the bolt so it won't fall out...now good luck it too me 8 hours to figure this out
Return to “Murano Forum”
