brikloft »
https://forums.nicoclub.com/brikloft-u268260.html
Tue Sep 20, 2016 1:59 pm
to:mrstomcrews
I had a similar issue with my 2006 murano. I was travel on the highway in the summer and I switched in between discs and that's when it happened. All six of my disks where stuck in there and wouldn't eject. I didn't have the battery issues like you did but still it clearly wasn't working. Did some research and it was mentioned that if you put a disc in that is has music burnt into it, these have a tendency to warp and cause issues with the device changing from disc to disc. Must be right, cause I changed from slot 1 to 2 and 2 had my burnt disc in it. I did some research on youtube and found out how to take the CD player out, so I did all that to get my discs out in hoping that it would magically start working again. got all the discs out, plugged it back in and it still wasn't working. I have an extended warranty on my murano and I took it to nissan for something else and I just happened to mention about the CD player and the warranty covered it, so I got a new 6 disc in there now. My only concern is, I would like to find out if the new CD player is in fact a new BOSE 6 disc, cause I feel like it sounds different.
Does anyone know if there's a non-bose 6 disc CD player that would replace the broken bose CD player. I've been told that if you have bose speakers its really hard to hook up any other deck to make it work properly.
Let me know
