I had a similar issue with the headlights acting weird. It ended up that my front left tire was eating through the wiring harness that runs through the driver side's fender.240addiction wrote:Problem number one: I had the wiring done by Wiring Specialties and have no check engine light or battery light the only lights I have when the car is in the on position are air bag, oil pressure, e brake. I also am having a weird issue with the brights indicator. Sometimes when I turn the lights on without the car running or running the brights light stays on. Even though the high beams are not on and does not change when the brights are turned on. According to the emails from the wiring guy I should have a check engine light and battery light. I have neither. What usually causes this problem? What is the deal with the brights indicator?
Problem number two: I am having an overheating issue with the car it is fine idling and driving for a few minutes then it starts to heat up really quick. I changed the thermostat tonight with an OEM one and it idled cooler then I drove for a few minutes and it started to get hot. I am running a stock sr Rad with the stock fan and shroud.
in the process of putting in the sr I did a 5 spd swap and I do not have a transmission harness hooked up right now but will shortly. would this have anything to do with any of my issues? I would no think that it would because the SR does not communicate with transmission like a KA does.
The car is bone stock 95 s14 with a red top . I am using the sr sidemount and all piping. I have a Greddy downpipe and stock cat with a apexi catback.
Any help would be great.
Modified by 240addiction at 12:24 AM 2/22/2007
Yuri did my wiring harness as well and I have nothing but good to say about the guy. He was a great help, especially since I had some wiring color discrepancies in my harness.240addiction wrote:my thoughts exactly the guy who did it responding to my emails but not with a ton of help. I did the wiring for my colt and that was easy, but the s13 inot an s14 seemed like more work it was worth. Now I am thinking that the 350 it cost me with shipping was a waste. I could have bought an upgraded rad with that.
Well some of the problems are fixed. The coolant temp sensor from the KA fixed the not overheating issue and made the gauge right. I also hooked up the alternator correctly and got a battery light. so a couple of my issues are fixed I think that i may have a boost leak now though. The car bucks under partial throttle. I still dont have a check engine light though and will be check to make sure the bulbs are not burnt out in the gauge cluster.SRPWR wrote:I had the same over heating problem. Did you take the temp sensor out of the KA? Its right above the TB on both engines, you must swap these also. If im not mistaken, its the single wire one on the right. Also, on the check engine light, mine dosent work either. I think it has to do with the changing of the OBDII to the OBDI. P.S. make sure you bleed the heck out of the cooling system. It will take some time because if it is a new swap, there is a lot of air that needs to be worked out.
