johnshop »
https://forums.nicoclub.com/johnshop-u208351.html
Thu Aug 16, 2012 9:35 pm
si i got this high mileage 300zx for cheap i think ( 2100 bucks) knowing it needed fixing. so i got to it.
i did a whole rebuild from the lower intake manifold up, new gaskets, replaced a dead injector, and a bad ignition coil, anyhow, with that i fixed the funny idling the car had.
now there's more trouble. and i have some questions.
the car is leaking,and i think one of the leaks is the rear main seal, and there's another leak on the vtc cams seals i think, the leaking is not bad, maybe a couple of drips overnight from the rear main seal and the vtc cams, is it safe to run the car like that? my actual oil pressure reads 60 when cold and goes down to the second line from the left when at running temp, the oil does build pressure when accelerating, all the way pass 60psi. is that normal? again, would it be safe to run the car like that? i will do an oil change some time next week, any specific oil i should be using/ buying? also, until i can cash out the dough to repair the leaks, are those stop leaks additives any good? or should i just walk past them and never look or think about them again?
another question is, and i seen some topics in here about it but i would like to be reassured, my knock sensor is out, the car in first gear has little power between 1k/and 3k, after 3k the car pulls really hard as it should, right now i can't afford a knock sensor replacement, and have all the top engine removed, so would it be too bad if i run the car bypassed for a week or 2 until i get the parts i need to relocate for now? i always use high octane gas btw.
hopefully you guys can help.
i want this car just to get me around my city, maybe 10 miles to 15 miles at most daily, maybe even less, and probably a couple of longer trips, like 290 miles round trip or so twice a month.
