GreenKryptonite »
https://forums.nicoclub.com/greenkryptonite-u18616.html
Mon Aug 02, 2004 12:54 pm
I have searched!!!!!! But i wanted to find any other opinions on what may be occuring. Here are the symptoms. Car was bogging out at idle when i turned off the a/c unit. Found spark plug wire loose (#4) ... reconnected. Still haveing problems with idling. Checked plugs wires again... #4 loose again. Replaced wires(cheepos) , plugs (bosch +4) distributer cap and rotor (el cheepo), O2 Sensor (bosch universal). Now after 3 weeks, i smell strong fumes on the driver side (outside) of my car smelling like gas. Leaking only condensation. Also now my car will lag especially while on cruise control @ 45 mph (being followed by cops) it felt like it should down shift but didnt. Noerror codes on ecu (55). Just recently (past 600 miles) put 3 quarts of SAE 50 valvaline VR1 and 1 Quart of lucas oil stabalizer + 1 K&N oil filter. Previous to that i flushed engine completly. My question is that what could be causing the smell of gas when there are no apparent leaks under my car or in my engine bay. i can only see the heat under my car (easily mistaken for vapors). Also what kind of oil to use i have 110,000 miles on my engine and the flush showed no oil leaks. Also after idling for a while i hear a noisy *** lifter.
Vehicle information:KA24DE 110kAutomatic trannys14 1995 240sx seInjen short ram intakeearth / ground kit((1 from batt (neg) to chasis))((from chassis to intake ground point, ))((from chasis to both engine grounds by headers.))
