crazyboy3012 wrote:I have had a few issues with my 2003 G35 lately. Just listing the problems 1 by 1 and hoping for some answer.
1. Keep getting the error code P1121 and this morning i got P0246. If I erase the codes, the car runs fine and the code pops up 3-4 days later. No issues with idling or power.
I have set up an appt with infiniti for a throttle body cleaning and resetting. Would that take care of it?
* A complete fuel injection cleaning was performed including the throttle body cleaning and resetting the idiling. Apparantly there were plenty of deposits on the throttle body. (119$ + tax)
I hope I exp better gas milage. (14 mpg in the city, 18 mpg on freeways before the throttle body and fuel injection cleaning)
2. in 2009, running lights were installed on my G when I moved from US to Canada. If I turn on the AC, my running lights does'nt work (I just realised it last sat when I was returning after watching the fireworks...not sure how long this has lasted) but at night it is a real issue coz I have no headlight. If I turn on the headlight, there is still nothing...if I turn off the AC they come back on.
* Canadian tire screwed up with the installation...they took the connection off the A/C unit...the dealership will rewire it the right way and take it off a different point. They also mentioned using new cables and a new relay. (185$+tax)
3. I have a rattling noise from the drivers side door...with the potholes in Montreal I have to keep hearing it all the time which bugs me...any idea how much it should cost to get it fixed at a local garage?
* They found one of the motors having a problem..part+labor quoted over 200$...decided not to do it...they will provide me with the P/N...planning to buy the part online and have it fixed at a local garage.
4. What parts (apart from spark plugs) needs to be replaced during a tune up for a first gen G35? Also, I have read some post regarding issues with NGK Iridium spark plugs. Should I upgrade from a platinum to iridium? My G has 88K miles, is it time for a tune up...I get very poor mileage and hence was wondering if a tune up is required.
* I was advised...at 87K the car is in good shape and that a tune is not required..They recommended a tune up close to 100K miles. Also recommended using a platinum spark plug instead of the iridium one as many first gen G's are getting SES light on when the iridium spark plugs are installed.
*I also got the 60K maintenance package done...which involves a complete check up and lubrication of the car, flushing and replacement of coolant, Automatic transmission fluid, differential fluid, brake fluid...replacement of air filter...surprisingly replacement of in cabin microfilter was considered extra...so I decided to do it myself. (449$+tax)
Hope this info will help someone.
Thanks!
