Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Wed Oct 20, 2004 5:08 am
IIRC, on the S13, the stock electric fan is controlled by a thermo switch and a relay. Very simple. If you want it to come on with the ignition, then just short out that thermo switch.
But if you've still got the KA radiator, thermo switch, and electric fan, then I would just leave them as they are. Your fan will not come on until your coolant hits about 85ºC, which is good for emissions and efficiency. If you wire your fan to come on with ignition, then your engine will take longer to reach operating temperature, which means you'll burn more fuel, pollute, stink up the garage, etc., while waiting for it to heat up. And chicks will avoid you because your car will smell like an Exxon refinery when it is cold.
