mrog71 »
https://forums.nicoclub.com/mrog71-u73858.html
Fri Mar 06, 2009 8:39 am
Hi All,
I've had the SES on for a couple months and I've been trying to track down the culprit, but now today things went to crap. The car is a 2000 Maxima SE (stick shift) with 135,000 miles. I bought it at 98,000 and have not replaced anything in the ignition/emissions system other than spark plugs.
I was accelerating and the engine starting hesitating and running rough. Then my SES started flashing. I read the codes, and there are 7 codes stored:
MIL DTC P0139 HO2S-12 (Bank 1 Sensor 2) Slow Response
Stored Codes P1320 Ignition Control Signal Circuit Malfunction P0138 HO2S-12 (Bank 1 Sensor 2) Circuit High Input (Rich Shift) P0140 HO2S-12 (Bank 1 Sensor 2) Insufficient Activity Detected P0430 Catalyst Efficiency Below Normal (Bank 2)
Pending Codes P1320 Ignition Control Signal Circuit Malfunction P0301 Cylinder 1 Misfire Detected Any suggestions? Sounds bad. Could bad coils (or coil) be causing all of this? I've read about the pre-cat issue, but I don't want to just shotgun and start replacing expensive components hoping that will fix it.
Any ideas will be appreciated - Thanks!
Matt
