Larz »
https://forums.nicoclub.com/larz-u216291.html
Tue Jan 16, 2018 5:27 pm
You can find them on Ebay, but most are, as you say, severely used. Just keep trying. They used to call that section of buttons the "multi switch". Now, I see them listed in the Infiniti Parts catalog as "Dash Control Unit" for the 2009 models. In case you wondered, they get $1046 from the dealer, but Infiniti Parts Online sell them for $787. Infiniti does not sell individual plastic buttons, just the whole piece. If it's that that individual plastic piece that is broken, then changing it out should be very easy. If the plastic button is not damaged (cracked or broken) you might need the entire multi switch. Probably not a bad idea to have a spare in case you need other buttons later on.
*** The buttons are easily removed. I removed mine when I covered the unit in 3M wrap. They 'pop out' from underneath after you remove the tiny screws that hold the black section to the rest of the unit. To remove the unit, you will need to take off the wood trim on either side, then remove the center switch panel.
