multichecker problem
F3600
Hey ive got some problem wiht my multichecker install.. when i hook the 2 wire for the crank signal my car refuse to start ... and my ecu is getting the error code for the crank angle sensor...
i dont know what to do ...is my unit defective ? ..im trying to install it on a ca18det Ecu
thx
NISTECH
your probably hooking it up to the wrong wire on the crank sensor. if you disconnect the multi checker wire will your car start?
F3600
Yes .. i verified10 times my wire harness in the multichecker booklet, my fsm... and i checked to the cas its the same color pattern for the 2 wire ... its pin 40 41. I switched the wire did the same thing... . i tried to connect the wire while the car is running and the car did not stop . i'm thinking about fitting a switch to the ground of the multichechker .. i start my car and flip the switch to power my mulitchecker and hope that everything work..:rolleyes
