Q45tech wrote:The oem designs have massive toe in braking/deceleration and toe out to neutral on 60 mph forces.........all a function of soft oem bushings.
Using harder or solid after market pieces means you have to reevaluate the oem toe alignment specs.
What you want is zero REAL toe at highway cruise.You will lose the self protective rear toe in - in deceleration to stablize the rear going into the apex of a curve.
Getting a zero thrust angle sitting still and at speed is tricky when you mix hard and soft toe bushings rear vs front .
