Multi-Function Switch - Stopped Responding
andrewclt
Car: 2008 M45S
New poster to this forum and relatively new to this car, but I've gained valuable info from this forum over the past 6-7 months. I've tried searching for help with my issue but haven't had much luck. Last night as I was leaving to head home, my GPS safety screen didn't come on when the car was cranked, went straight to temperature controls and radio screen. So I pushed the Map button and nothing happened. Then realized Map, Destination, and Route buttons did nothing, netiher did the direction buttons, or the center, Back or Voice buttons on the centrol control wheel. Also, #1 of the radio pre-set buttons also did nothing. Very strange. I can access GPS through Voice controls but that is it, so now it perpetually tries to navigate me to that one destination that was programmed in when the buttons failed. I can change it via voice, but I can't cancel the route via voice (must cancel with the Route button). I plan to check fuses tonight and also remove the control panel and look for loose connections but the Service Manual Instrument Panel (IP) section doesn't pull up from the link that is provided in this forum. I need page IP-11. All the other service manuals work, but for some reason that one doesn't. Would someone offer me assistance in what I need to remove to gain access to the connections to the Multi-Function controls? Also, if anyone has ideas on why my buttons suddenly stopped working, I'm open to ideas!
Thanks!
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
you may need to replace the hole unit you have warrenty?
andrewclt
Car: 2008 M45S
Warranty was up 2,000 miles and 3 months ago, unfortunately. But... last night after looking and checking everything I could, I got in to go out, plugged in my iPhone to play some music, tried the Map button, and worked liked nothing happened. They all work now, so catastrophe avoided for now. Very strange how having a phone plugged in fixed the problem of all those buttons not working. But tested many time now without phone and all work fine. Whew!
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
You might want to think about purchasing a used multi-function switch control panel off of fleabay just in case, if yur a glass half full type of person--cuz the stealership price will certainly be waaay over the top.
sounds like a short of some kind, or potential failure of the board, haven't seen any posts wrt this problem
the electronics in the infiniti while very cool, can be finicky at times and mucho dinero to replace if not under warranty
sbabakov
Car: Infiniti M37 Y51 2012 AWD
Hello dear! Have you solved this issue? I have the same. But in totaly sonar parking do not response also. i dint know what to do.
