renkema »
https://forums.nicoclub.com/renkema-u49228.html
Thu Oct 19, 2006 4:54 pm
Found serveral references to this in both current and archive, but none went to the heart of my issue.
I have a '97 q45t that's been nothing but sweetness and light for 92k miles. Today, while walking to the car, I inadvertently setoff the alarm via the keyfob. I cancelled it, started the car and began to get the symtoms of a misfire while going up a hill. This continued to the dealership where they tested and said I had codes indicating a multi cyliner misfire. They suggested I fix the problem by replacing ALL of the coils and the 2 knock sensors (only $3,500). They said that should fix the problem as they had NO way of ascertaining which coil was bad. I had it there for service 2 weeks ago. All they noted was that there was at some point (not currently), knock sensor codes gerenated.
I have 3 basic questions. 1) Are they even on the right track as I've seen references here that suggest other problems and,2) is it really impossible to discern which coil is bad 3) are the knock sensors the potential culprit.
I called an out of state infiniti dealer's parts dept that I've ordered from before and they said that the all 8 approach didn't ring true. The parts guy looked up coil orders from his own shop and 95% of the orders for coils were singles (no 8 at once). On top of that, my local dealer shop only had 3 instock and was pressureing me to go ahead and order the 5 more so they could do the work the next day.
All of this may be legitimate, but at 200+ a pop, I would think there would be a way to determine which coil was bad. I'm thinking worst case, I 'll put the coils on myself and save the $1000 in plugs and labor they want to install all 8. I don't think I can install the knock sensors. I installed a transmission in an '89 honda, but I think these newer cars require more skill and tools than I have.
I'm not looking to pan my dealer, but I would like some help on determining if their advice is helpful or self-serving.
I'm new to the forum. Hopefully, I'm following protocol in all respects. Let me know if I'm not. Thanks
