lofapoo »
https://forums.nicoclub.com/lofapoo-u12390.html
Mon Jan 23, 2006 5:27 pm
Or am I just paranoid?
My muffler came "un-done" from my exhaust system, and I was wondering how the insides could be so caked if it was running right. I believe it was replaced by the PO somewhere down the line but if not then this could be a explained a bit easier. My guess is that either it got hit by one too many speedbumps, ****ty muffler quality, or possible corrosion. Maybe you could give me some advice based on the pictures? Car seems to run just fine; rarely died on me when cold, perhaps a slight electrical issue (grounds? alternator? idle?) with the headlights - they are dimmer at idle but once you give it a little gas they brighten up. Also has a tapping noise coming from engine bay at times (not timing chain), but I doubt it could be related unless it's a tapping valve causing burnt oil or unburned gas flow through the exhaust? Forgive my ignorance, I just wan't my ride running right.
Look at the bottom of the bumper above where the exhaust should be. The blackness is not like normal dirt from the roads which is easily removed with a good wash of the car. I've seen this sort of thing happen with cars running rich or burning oil.
Looking down into the hole where the inlet stub should be. It was ripped right off the muffler. Corrosion + speedbump, or just too many speedbumps?
Old turd sleeping with the worms. Another shot of the ripped hole.
Looking into the exhaust piping
The rest of the muffler, still attached (welded on, yay now I get to cut the pipe to put the new one on)
Looking into the tail pipe, one of the tips MIA due to speedbumps
Another shot
Already got a new OEM muffler with all I need to install it correctly, after I cut the pipe to fit the extention pipe over it so I can pass emissions this month, and hopefully I won't find some bad news about the running condition of my KA.
