GNR4ALL wrote:Would a straight pipe add, decrease, or maintain the same performance? would it really only be 2% louder and would i have problems passing New York state inspection?
Modified by GNR4ALL at 2:49 PM 5/3/2007
Performance difference is negligible (i have straight pipe currently). NY has emissions test that measures the amount of emission (we have it in PA as well). However putting straight pipe instead of the resonator does not fail the inspection since there isnt more emissions. The noise is not necessary louder just a little more throatier. I would recommedn that you do it and make sure that they only cut within the bolted section. That way if you dont like it worst case scenario you unbolt the section and intall the OEM section.
Feel free to ask any other question u have i just personally went through this ordeal in the last month. If you search there are a couple of threads that i have made in the lsast month regarding this topic.
