Muffler cover on Rogue 2015 - Can it be painted?
domo325
Car: Nissan Rogue 2015
Can this steel cover be painted? Would like to paint this black. If so, what kind of paint can I use? I'm thinking caliper paint that is heat resistant, epoxy type paint. Is this suitable?
I found this one on ebay...
http://www.ebay.com/itm/BLACK-G2-BRAKE- ... 5731.m3795
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
If it's stainless steel I wouldn't recommend it, but I'm guessing that won't stop you. Just realize it's going to take a lot more work than just spraying a coat of paint on it. If you want it to last you'll need to prep it and apply multiple coats, with additional work to each layer.
12 oz. Bar-B-Que Black Satin High Heat Spray Paint $3.76 /each
  • High Heat Spray Paint retains color and finish up to 1200 degrees
  • Use on exterior of grills, radiators, fireplace screens and more
  • Paint holds up over time during repeated heating
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
followingnfront
Car: 2017 Maxima S
Plastidip. Only prep work necessary is cleaning it. Durable, easy to use, and you'll only need one can so its cheap too
domo325
Rogue One wrote:If it's stainless steel I wouldn't recommend it, but I'm guessing that won't stop you. Just realize it's going to take a lot more work than just spraying a coat of paint on it. If you want it to last you'll need to prep it and apply multiple coats, with additional work to each layer.
Hey, just wondering why you would not recommend painting stainless steel.
So I bought the rust oleum high heat automotive spray paint as suggested above from home depot. Now I'm reading that for best results, using a high heat primer would be beneficial in order for the paint to last longer on stainless steel. Is this true?
I am looking to purchase this..
https://www.amazon.com/Rust-Oleum-24934 ... YKY8KA85H0
Or is it not needed at all? Also, should I sand the steel cover before applying the spray paint? Looking to do this DIY over this weekend.
followingnfront
Car: 2017 Maxima S
Dude... Plastidip
Return to “Rogue Forum”
